Will L.
Skip 2 minutesHmmmm . . . Wonder if the same principle applies to flatulence![]()
ok, so it sounds like there's not much chance of this old 6.5 sounding like that, but the whistle SS Force posted sounds great to me. Does the ATT sound as good? A while back, I had asked about the HX 35 or 40 vs the ATT and it sounded like the ATT was the better choice, although maybe I cannot have performance and the distinct whistle, both?
The reasoning for the turbo that whistles so loud, is it spools all the time. Even the LBZ makes boost at idle in gear(almost a pound). When they can make boost so easily, you can get better throttle response because you'renot waiting for air. Since it's a vgt, they can open up fairly good on the top end.I like whistle sounding turbos, and turbos are definately not my arena- but...
Whistle real quick while reading this... You pushed a lot of air through a tiny opening in your lips. Open up your mouth and breathe is far more productive. Seems to me more appropriate sized orifice doesn't whistle. It just moves the air through...
Nothing like a Communist HOA of 100+ more landloards to tell you what to do or what you can or can not do with your property. What Freedom and tolerance for others? And as you found out you are target #2!
Yes noise can sound good till you have to take a long drive and it gets old to the point of fatigue.
THIS is a WHISTLER! Turbo from an M35 deuce.
