jrsavoie
Recruit
You can test them without removing them with a continuity tester. If you have a multi tester with a buzzer, the buzzer should be buzzing. Disconnect the wire going to the glow plug, Put one probe on the spade connector on the glow plug and the other test lead goes to ground. You should read a max of .02 Ohms or something like that.
Sometimes I will hook up 2 testers and test for continuity from the glow plug controller to each glow plug connector as long as I am there. Doesn't matter if the glow plugs are good if they are not getting juiced.
