Overall, excellent information and just makes me want to ditch the 4L80E even more
For clarity though . . .
Am *not* thinking about locking the TCC in 2'nd for daily driving.
Question *is* about locking the TCC in 2'nd while pulling hard.
Scenario:
> Pulling a trailer.
> Enter grade (5%+) at speed and apply power. Depending on the length of grade, I do not go WOT as the cooling stack is not going to dump the heat by the time I crest. If I hold the power according to EGT's, the motor will stay within desirable temps.
> Immediately drop to 3'rd with TCC locked.
> Speed decreases due to load even though applying power.
> Gears drop due to decrease in speed. Power remains heavy.
> TCC at some point in 2'nd unlocks do to further drop in speed.
> If necessary, drop to 1'st which is always TCC unlocked.
Currently (in the above scenario) I manually control the RPM's to keep them above 2,200 as the ECM will let them drop to about 1,650 (presuming a 3.73 rear and OE tires) before downshifting which is too low for my preferences. Seeing as I am not the only driver of the truck, I want the ECM to do a better job of managing gears while climbing so that others can simply drive it and not have to work it.
Toward the end result, am looking to have the ECM keep the RPM's above 2,200 in the above scenario for maximum cooling. Also want to keep the TCC locked as much as possible, but at some point I will have to just let it unlock if the load drops the RPM's too much in 2'nd. Naturally, 1'st will run unlocked.
And by the way, I picked +/- 2,200 RPM's as the downshift point (depending on gear) as it is a fairly good transition point to not over-rev on the lower gear.
In the end, if the TCC I have only has a service life of 50K from towing, then it is not likely that moving the shift behavior around (based on the scenario) is going to have much effect on that anyway seeing as it is either going to tow, or it is going to tow
In re-reading my original post, I was not clear enough, left out too much detail, and apologize. So, back to the original question . . .
Can 2'nd gear handle getting locked-in while pulling hard?
Transmission rebuilds cost a flat $1100. Yank Converter any way you want it is $1100. So is the cost for a 6 speed similar?
Nope . . .
Am seeing the price range for just the '6 speed 4L80E' tranny is $5,300 - $7K, add in things like the TCC, shift controller, and re-gearing to 3.42's and the drivetrain just cost more than the truck. But it is only money, right?
The factory ECM will lock the TCC in 3rd gear at WOT at a specific temperature to keep temps from running away.
From what I can tell, Yes and No.
In looking at the tables that I am aware of, it does this for 4th at 44 mph, 3'rd at 35 mph, and 2'nd at 25 mph. The TCC lock speeds are flat for all the same for power levels (and not just WOT). Only variable I do not know is the TFT set point and had read that it is either 240F or 270F. From what I can tell, the speeds are changeable, but do not know whether the TFT Hot is a variable or hard coded.
