FellowTraveler
I've been running an ARB locker for the GM IFS 9.25" since back when they were first introduced for the GM 9.25" IFS DIFF and just did 'O' ring, bearing and seal replacement topped off w/AMSOIL.
With an air locker gear lube will spit out the differential vent when carrier air engagement hub 'O' ring (s) gets excessive wear and leaks air pressurizing the case, there is a purge valve manifold that can be installed to relieve the pressure after 4wd use but replacing the 'O" rings is the only real fix.
I love the true 4x4 of front & rear lockers............
