turbovanman
I has boost, :O)
Yuck.
Yep, poly!Are those the poly ones? If so then yes. I was referring to the cheap chinese rubber ones.
Uh oh....I'm learning as I go, so don't consider it learning until we see how it turns out!!cool, thanks for the explanation. Keep posting! I am learning a lot from this thread.
Nate, what diff does your Tahoe currently have, 8.5? If so, that larger diff is a wise choice with your setup.
Those lifters should work perfectly for checking your clearance. Nice work.
Matt
I was going to say he wanted to convert to solid lifters.![]()
Far better than what is under there now nice indeed.Got another goody today....not for the engine but for the truck itself. A 14 bolt, 6 lug semi floater. My brother got it for me from the shop he works at for $25 and a case of Miller Lite. The pinion bearing blew up and took out the ring and pinion too, but the housing and G80 posi are hopefully still good. I figure I can rebuild it and have an axle with new internals for about the same price as a "good used" one (assuming it looks ok once I fully disassemble it). I know what I'm doing after the engine and trans swap
Got super lucky today....a friend of mine had an electronic boost controller he wasn't using anymore so he gave it to me!!After the engine is in and broken in, then I can start playing with the boost from the cab! This will be really handy so I can run lower boost while towing (for durability), but when I'm running unloaded, which is most of the time, I can crank it up! I'm super excited to try this thing out!!
Interesting, however the diesel vacuum pump is constant vacuum and gasser is variable vacuum will this unit work with the diesel, or?
