trouttrooper
Big Blocks ROCK!!!
Didn't really get much help at the forum for this platform so I thought I'd run it by you guys.
2003 GMC Envoy XL: 4.3l, 4x4, 176,000 miles, manual HVAC dual climate control.
We've only had this for a little over a year now and I've been slowly fixing all the little issues it came with. I swear some people just don't know how to take care of things. On the plus side the price was substantially lower because of all the little issues. Nothing complicated or expensive for a DIY'er and I've got 95% of the issues fixed.
Anyway, here's the issue I'm not sure on what to replace. The passenger side temp control will occasionally act up. When the selector near or at the hottest setting (all the way up) it will sometimes out of the blue start blowing cold air. I can "reset" it by sliding the switch all the way to cold and then back up to heat. It appears to be completely random, sometimes it will be fine for days then one day it will act up multiple times.
Is it the slider switch causing this or something else? I was going to try and fix it this past summer, but I don't use the heater in the summer and forgot all about this little issue until it started being 5 degrees outside.....oops
