The DB2's want the lower pressure Walbro FRB-5 as the timing is determined by housing pressure that changes from the DB2's rotary vane pump RPM, of course, the pressure relief is referenced on the inlet of the IP. In fact if you remove the fuel inlet pipe you can stick an Allen wrench into the adjustment screw on the housing pressure regulator. It's possible to peg the timing on a DB2 with too much lift pump pressure, let alone bring it on too soon.
As I understand it the DS4 is immune to high lift pump pressures.
