bowtiebutler956
Active Member
I love all the info here! Thanks Missy, and WarWagon for the very extensive, and detailed posts. So I assume both of you buy the aftermarket 180 T-stats? Where do you get them. I did some searching, and about the only brand I could find in a 180 is MotoRad, (part #332-180, and 7332-180) and it doesn't look like a very high quality t-stat, and looks just like the one SS is selling.
As far as the fan clutch goes, I got a Four Seasons severe duty #36754, as it can still be modified for early engagment. The Hayden clutches have a different design that doesn't permit mods. Here are a couple pics of my new clutch. I was able to move about 1/4in. back into the coil to help it engage earlier. This left just enough of a tang to keep it located properly in the slot. All I have left to do, is silicone it back in.
Matt
The pics are a little out of order.
Pics 1, 2, and 5 are of the clutch right after purchace.
Pic 3 is of the front coil after modification.
Pic 4 is of the coil before modification.
For anyone not familiar with this mod, I didn't cut the coil. You bend it so that you end up adding more to the coiled up section, which helps it to engage sooner.
Matt
