3500_6.5
I have decided to cut my losses with the electronic "power" build and go mechanical. Just not going to get the power I was wanting out of the electronic setup. I had decided on the Moose pump when I first decided to go mechanical. Can't beat the price at under $800 for 120-130cc db2 pump. Was planning on running that and my ATT and figured it would be a pretty nice setup. However, I came across R&D and found that they build a pump that is capable of up to 180cc of fuel... They have two versions, 150cc and 180cc. It's over double the price but I am selling off some things and will have enough extra money to maybe splurge for the pump. However, if I go that route, I am not so sure the turbo will be efficient enough to burn all the fuel and keep drive pressures down. So, if I end up with this pump, I will be looking into a compound setup. Since there is an array of Holsets available and seems that there are tons of combinations to choose from, I was think of going with them. My problem is that I don't really know a whole lot about them. I have been reading up on them but it seems there are so many different Holset's people are running that its hard to really figure out what is what and what might work best. I was originally thinking of running a hx35 and hx50. From what I have heard of the hx35 it seems to be a fairly quick spooling and efficient turbo. And the hx50 should be plenty big enough to give it a nice gradual boost as rpms climb. But I know there are different housings and such that can be ran on the hx35 and I am sure the same goes for the hx50.
So basically what I am looking for here is any input from guys that know a great deal about the Holsets. If anyone has some helpful tips or suggestions with the turbos or if you think its a bad combo. I'm all ears. This will be the first compound setup I have done and is by far the most extreme I've gone with a 6.5. So I want to make sure I am getting the turbo selection right on this. Don't want to be buying more turbos than I have to...
I am not dead set on the compound turbos or even the RD4 pump, but it is definitely looking like it could be a possibility. Hopefully will know for sure within the next week which route I will be going. But I guess that will also depend on what feedback I get from all the turbo guys out there. Thanks for the help!
