Update: still trying
:holyshirt: She still isn't going. Still havn't started replacing parts blindly. Can't afford to. Here is an update on what I have tried.
Put a clear hose from fuel filter to IP, No air in lines.
Pulled the screen filter at inlet on IP and cleaned.
Checked return line.
Rechecked fuel shut off solenoid. It seemed to work properly. I pulled the insides of the Fuel shut off solenoid out and tried. Same same.
Tried yet another CPS. Still no luck. All of them have had the same part number 12557046 on them. This is not the same as the original 10154687. Can't find any different part to try.
She still cranks and runs sometimes. If you mash the accelerator while it is running it will die when it reaches 2000 rpm +-.
Most of the time it while crank and die immedietly.
Always have code 19 after it cranks, or tries to crank. Sometimes throws an 18 in with it. Oh yeah, Fuel gauge acted funny for a little while when I was working on it. It would peg all the way over. After draining the tank I only put back in a few gallons. She is lower in fuel than I have ever let her get before.
It always cranks and runs fine with optic sensor or CPS unplugged in limp mode.
Other things I am debating trying when cash allows in the order I may try them.
Remove intake. Check all wires from IP, sensors, ect, all the way back to as far as I can check. Remove old PMD while I am in there. Take the resistor out and put in newer pmd and see what happens. Replace return fuel line while I can get to it. Make sure return line is functional. Clean out the rest of the crap left by rodents. I found a huge nest of junk that had been there since before I bought the truck.
Tear into the front of the engine and see if I damaged what the CPS reads from when I removed the CPS. Any suggestions? Replace timing chain front seal ect while I am in there. Could these problems be caused by a loose timing chain?
New PMD or good used. Can't afford either yet. Anyone have a known good used they would sell cheap?
Replace IP with a new or rebuilt. I hope this isn't it since it will be a while before I can afford it.
All suggestions and help is greatly appreciated.
PLEASE HELP!
