Mezmorized
Member
Due to a fuel problem I'm having (getting air in the FFM), I've decided to go ahead and install my auxiliary fuel tank that I bought for the truck 2 years ago. I'll be installing a Baldwin FB1301 filter base on the frame between the tank and the LP. The FB1301 has 2 inlets and 2 outlets
The 2 inlets are perpendicular to each other and the 2 outlets are horizontal and opposite each other.
The aux. tank will be plumbed to the vertical inlet with a ball valve at the filter base. The stock tank will be plumbed to the horizontal inlet also with a ball valve. The outlet facing the rear of the truck will be blocked and the outlet facing the front of the truck will be plumbed to the LP.
I will be installing a T in the return line that will also be plumbed with ball valves (one to each tank).
This way, I will be able to isolate the the tanks from each other in hopes that the air issue is in the line from the tank to the filter base. Having the tanks isolated from each other leaves me with having to T the return line. Or else, if I was running the aux. tank by itself, I would be slowly filling the main tank with the return line.
By the time I'm done, I will have also done the LP relay mod, replaced the OPS and do the GP relay mod.
The reason behind doing it this way is to isolate the suspected issue without spending a pile of money doing it. I already have the aux. tank and I've been meaning to install it anyway.
If, by chance, it does not solve the issue, then I would not have wasted time dropping the stock tank to check things out, replace parts and hope for the best. If it does solve the issue, then I can plan on getting a new sending unit and replacing the existing lines to the main tank.
Fingers crossed, I hope the weather is good enough to get started on it tomorrow
The 2 inlets are perpendicular to each other and the 2 outlets are horizontal and opposite each other. The aux. tank will be plumbed to the vertical inlet with a ball valve at the filter base. The stock tank will be plumbed to the horizontal inlet also with a ball valve. The outlet facing the rear of the truck will be blocked and the outlet facing the front of the truck will be plumbed to the LP.
