DieselSlug
That's the setup I put in for my powered mirrors. I only found the drivers side in the pick-n-pull, so my passenger side is still as it came from the factory.
The stock door panel can be easily modified to accept the Burb switches. The metal inner door panel already has the slots for the metal clips. All you will need to do is put the clips in place. The switches will need to have the wires put into the Burb connectors as the pickup connectors do not interchange. It really isn't hard to do.
I did have to get some plastic paint since I needed grey and the panel parts were tan.
Don
So the connectors are the same on the end of the pigtail wires? All you have to do is install the pigtail wires from the old plastic housing to the new ones? Or do you need to cut the wires and add new ends? I didn't look into this project real close yet.
