What's YOUR opinion on splayed mains?
I use them on my SBC 400 motor. only way to handle any serious power in that weak block... I don't see much point to it using a cast crank though...
I'm all for it myslef if you can afford it and your block has the meat for it.
And moved to 6.5 performace as it seems more appropriate here than the regular 6.5 section.
Let me add a question for discussion. Which would be better and more feasible.....splayed or girdled? I have not tested this on racing gas engines either.
depends on the girdle. if it's just one of the store bought units then splayed is better IMO. if it's a full on girdle like the p400 than I think the girdle would be better
There are more arguments against a girdle than splayed.
Cost is the main problem with splayed. Girdles aren't made out of the same cast iron as the block so they won't expand at the same rate which could cause more stress than it stops.
Girdles just ensure all of the mains move together and can actually break more.
The only bad thing I see with splayed mains is cost. The structural improvements are proven
