Not sure if I am moving the throttle back up after snapping it to a value or if this is a sensor going out. The quick up and down was movement looking for odd readings. Both voltages change indicating likely movement. (or a ground starting to float?)
Getting throttle surge in parking lots and very bumpy roads. I suspect it is throwing me around and amplified by the typical hypersensitive LLY throttle.
