Well, yes........and no.
Building a calibration takes into account more than just fuel.
If you just dump in more fuel and leave everything else alone, you'll get more smoke in your case since it sounds like you're just below the "smoke point".
However, timing has a huge effect on everything from smoke to power to egts to turbo transient time.
It's a balancing act.
For example: you may adjust the timing at you current fueling level and find the turbo hits it's minimum boost (for the engine demand) sooner. This allows you to bring in fuel sooner, which increases available drive pressure, which brings the turbo on speed sooner and makes more mass flow, which enables you to adjust timing, which........and on and on.
There's many other things to consider also, like transmission shift points, lockup, line pressures, abuse management, scalers, etc, etc, etc.....all of which can have a visible effect on the turbo response (one of the things we all like to watch).
This is why it costs a fair bit for a custom "tune" in the average Joe's eyes: there's hundreds (sometimes thousands) of hours in development and more money than I care to think about in fuel and hard parts in testing to optimize a system. Even after all that, most guys never even get there...heartbreak, just pure heartbreak (not to mention wallet abuse).
The thing lots of guys seem to forget (or not understand) is that you can't just adjust one variable (in this case, turbocharger) on an engine system and call it a day.
Well, you can, but you're not getting what it's capable of.
You need to adjust all the components of the system to work with each other. That means intake paths, exhaust paths, calibration, gearing, and so on and so on.....changing one factor starts a "domino effect" and halfway through the domino run you may look back to discover something you've done has stood the first domino back up again and brought you right back to the beginning, starting the domino's falling again....sheesh.
In this case, you've changed the nature of the turbocharger and it's interaction with the engine system. In turn, you need to optimize the entire engine system to give the turbo what it needs to give the engine what it needs to give your right foot what it needs to put that big "S-eatin' grin" on your face.
That's what it's all about anyways......isn't it?
