Do I need to remove the Serpentine belt to figure out the size? I checked on NAPA, and there were 8 different choices. I know I only have 1 alternator, but I don't know what draw it has...Do I have a vacuum pump? If I do, what's it power? And I have A/C. So, I guess I need help figuring out the vacuum pump & draw of alternator.
You Do Not have a vacuum pump. We'll have to do some digging to find your belt
Also, can the egr be plugged under the tube instead of near the firewall (temporarily and would it make any difference)? Also, I can understand the delete plate for what's near the firewall, and the tube that will connect on top, but what about the piece under the tube? And the huge electrical plug that plugs into it? (I mean, I understand the finger stick(?) replaces something in there...but that plug that's in the end of the egr system looks rather complex... (I sure hope you guys know what I'm talking about)The "tube" you are talking about with the connector sticking out of it is the EGR motor. Plugging the EGR with a plate is the only way to do the job.
Also, where am I supposed to get the new o-rings for when I change out the fuel filter? Are they THAT necessary?
