If I go to the dealership to get a reflash for the cd player, should I wait till I get the lbz mouthpiece installed?
Doesn't matter but checking for the idle surge reflash at the same time is a good idea And when I do the lbz mouthpiece, since I'll be checking with salvage places, should I see if I can get the airbox too,
Both and just replace the whole system with the lbz induction system?
Yes I checked the S&B and saw that it was just the airbox, but doesn't have the mouthpiece, so I'll make the mouthpiece the priority.
As far as manuals, I see a helms full service manual for a silverado sierra/sierra denali (
http://www.helminc.com/helm/Result....005&Category=&Keyword=&Module=&selected_media= ) but I don't know if that includes my truck. There is also the option of Alldatadiy -
https://checkout.alldatadiy.com/adecomm/diyecomm/checkout?execution=e2s3 - which is cheaper, but I don't know which of the 2 would be the best. I like the idea of a hard copy, simply because I like the option of having info available w/o internet. If alldatadiy is an option, tts and duramaxdiesel would probably be just as good, if not better...
I wouldn't spend the $ right now. You've got plenty of online help
I think I'm going with the Edge Insight CTS and the Diablo Predator U7185. Just to clarify, but the predator is similar to the superchips I had for my 24 cummins, where you plug it into the OBDII port to change the settings, and then unplug it. You don't actually drive with the predator plugged in, right?
Right. The tune is loaded and then the unit is unplugged. Because the Edge Insight has to be plugged in. Both the Insight & Predator can be updated online too.
For the egr delete, I'm looking at creatures of the night performance website and there are so many egr delete options (a tube, plate, cap, and delete plate) - what's the difference between them all? And he has intake/boost parts on the same page as the egr, too. I guess my question is, soooooo many choices, how do I know which one I should choose?
For now I would suggest a blocker plate and Finger stick (because you aren't going EFI right now). I know you can get them fromAll Seasons if Henry (Creatures...) doesn't have them.It was suggested that I do my egr when I do the FPR, but I'm hoping that a new fuel filter + trans fluid will clear that up and I won't have to do it. If I do, do I have to purchase the new FPR from the stealership, or get it from someplace else? (for the additional viewers of this - Warwagon's fpr KISS write-up:
http://www.thetruckstop.us/forum/sh...FPR-install&highlight=fuel+pressure+regulator) Also, where do I get at heavy throttle spring?
I would not plan the FPR replace unless you are SURE you need to.
There is an exhaust place in town that sells MBRP exhaust, and I think I might get a price check on duals w/o cat or muffler. What's the safest minimum size I should go with exhaust, whether its duals or single (4"-?")? (Also, would it be safer to get a single exhaust for the duramax? Because I never see dual exhaust for diesels, unless it's stacked...)
I'd suggest MBRP 4 or 5" single
I plan on doing the HOOT method & probably a coolant drain when I get the Predator, but not before...unless it's advised after all the filters are replaced. That way I can get more familiar with the truck and also save up a little for everything. And I'm planning on doing the mouthpiece, than either the Insight and/or exhaust, than predator. I don't want to be pumping more power if it can't breath.
As far as if its cloth or leather, its leather. Heated leather seats & automatic controls up front. All the comforts inside. Way down the road, I may go searching for a middle seat and check around for leather upholsterers, since there's no such thing as a leather front middle seat...it'd have to be a custom item. Also looking into the roll-out toolbox that sits in the bed of the truck (4' x 6') - then I can keep my tools in the bed, but still have the full length & width of the bed. I'll just lose 8-12" of height...I think.
I'll try and post some more pics when I get a chance.
