racedaymechanic
Member
By moving the Battery it opens up alot of room for an airbox, I am reusing the stock one with some mods, I am going to just use 1 4 inch 90* bend into the turbo from the air box
I opened up the original hole to fit the new intake
Here it is after the epoxy is on
This is to be continued I will be using 3 inch flexible brake hose to go from the airbox to where to old spot behind the signal light
