The RM can be "set" for desired rate, when installing/setting rate the leafs are let "hang" at full extension then the RM spring is adjusted with a quarter or a dime inserted in the gaps between coils sort of as a feeler gauge & set depending on stiffness desired,
This setting tensions the RM springs to a "null" position with regard to the OEM leafs, then as weight is added to bed then is when the RM spring starts "working" as load tries to stretch the spring, if it isn't under load from a ride perspective it is in the null position where your springs do not move away from the standard leaf spring compression it sits with at rest, RM springs only become 'active" when a load is added that tries to go beyond the resting setpoint of your stock springs.
Also works to improve handling when empty as in a slalom like manouver/cornering the axles tendency for one to try to lead the other in the turn is dampened. hard to describe well, it has to be ridden as a before & after install to know the difference or be someone with a non RM rig vs one with same truck style to be attuned enough to the ride of each setup to get the "ahaa" I get it feeling.
