started working on it about 1 pm yesterday, didn't finish it but ended at about 9 pm.
replaced the 4 GP's on the right side and reworked the turbo drain on the bottom. the
old hose was dry and leaking.
here it is before:
nothing special.
_______
start teardown,removed air filter, top intake, boot, bypass oil filter:
tried to remove the turbo bolts but it wasn't happening so i took out the manifold, one of
the reasons it took longer. of course disconnected the crossover, turbo discharge, and manifold
bolts and turbo oil discharge.(and i dropped the donut but didn't realize it)
big empty space now. look at oil return, not seated properly, oil leaks:
this is a GM3 so if anyone is needing one, let me know. i will clean it up. no play.
heated nuts w/ torch and they came off w/ ease axcept one. it would have been a pain to remove
still installed:
removed oil drain,
cut at the right spot, nice clean slice:
then modded the connection using step drill and cutoff wheel:
installed, cut off (shortened) allen wrench, don't forget supplied gasket:
marked intake for removal:
used thin cut-off wheel, clean slice:
ATT bolted up after exhaust put back w/ NeverSieze:
clocked, ready for boot:
oil feed to supplied fitting and boot on:
exit installed. for me, it was easier to mount to down pipe then install to turbo. had a time
trying to get it mounted w/ the exit on the turbo because there just wasn't enough hands to
hold it and tighten clamp:
Boot Shot, diesel porn:
i will be using the same intake filter i had on the GM3 so i am hoping i don't get a
collapsed filter.
finished install:
this vid is dry start up to preload the turbo with oil. let it crank for 15 seconds:
http://www.youtube.com/watch?v=W3PbQ1bLU3o
this is the first start up after install. the smoke from under the hood is because i left the
donut off the crossover. i did put it back on though:
http://www.youtube.com/watch?v=YrEhS61LB78
hear is the exhaust but didn't notice a change there:
http://www.youtube.com/watch?v=T6BfzID_qvc
where the change is that i noticed right off, under the hood. around 1600-1800 rpm, it
sounds like a semi truck and it sounded good! a little whistle if locked in 1st and hit
the pedal. boost was 2 psi at 1900 rpm but i have a 30 psi gauge so don't know if it's accurate.
acceleration on overpasses was better than before and feels like it has more acceleration
on the flats. filter is holding up so far but just drove 20 miles or so. will be
driving 120 miles tonight on a work run.
will keep posted.................
here it is before:
nothing special.
_______
still installed:
removed oil drain,
collapsed filter.
finished install:
