Save the throttle cable. Not available any longer.
I wonder what the MPGs were on that? had to be 23+
Yep, saved the cable.Save the throttle cable. Not available any longer.
sounds like a line lock
that clutch has been hot a time or two
these NV 4500 trannys drain trough the bottom PTO cover bolt hole.
That T-case is prob trash.
looks like the PO didn't know the words "reg maintenance":nonod:
PM sent:hello:Would you happen to have the Accelerator Pedal Position Sensor?? Need one badly for 99 6.5. 94 to 01 will fit.
I plan to use the case for a learning piece. I've never had one apart before. I'm not going to fix it,just take it apart to see how they work. I have 3 other spare cases.
take pics i have one that i need to rebuild!!!!!
