NVW
I bought the truck three years ago from a member of the Place as a non running truck. He had put on new heads from a good friend of Jim's:rolleyes5:, called Teds something or other in Calgary. There was a coolant in oil issue IIRC.
I hauled the truck home and got it running, oil pressure was 40 psi at idle until it warmed up with a slight knock, after it got warm the knock increased and oil pressure fell.
A comp. test showed 7 cylinders at about 360-400 psi, # 3 was about 225 psi.
Earlier in the week I pulled the engine.
