Woody35
Active Member
S engine is rated at 185 hp and 360 torque. feels like a stock 350 on steriods.
Care to drop any names?
Peninsular Diesel does offer properly ported cylinder heads. $900 each when I called them a few months ago. Also any shop that has worked on performance engines, have a flow bench, coupled with experience should be able to do a good job as well.
You certainly can put in bigger valves too, Manley will happily make you a set, you just have to give them all the dimensions and material you would like to use. Then have your heads machined out to accept the larger valves![]()
It has been mentioned that with a turbo it isn't likely to have the same benefit as a N/A engine
Leo
GM induction hardened the valve area of the heads instead of conventional valve seat inserts. I'm no metalurgist, but I'm told it's not unheard of to get cracks thru that seat area. When GM first started building the 6.2, they had larger valve diameters. As time went on, GM stepped down valve sizes a bit, supposedly to lessen potential cracking issues btwn the valves.
If keeping the stock 6.5 sized valves, there is enough material in the seat area to machine out the opening & install hardened valve seats. My cyl head shop said they were very leary of trying to go w/ the earlier, bigger valves & hardened seats because there wasn't sufficient material left after machining to fit the larger valve seats.
Ian can possibly confirm, but I believe the articles on Heath's Bonneville engine said they fitted the larger valves & just machined the larger seats into the cast iron - recognizing that some of the new, larger valve seat area being machined into the head gets outside the induction hardened area. So it probably wouldn't have the wear resistance for OEM longterm durability levels.
On my 6.5 heads, the area just below the valve seats would benefit from smoothing/blending into the valve bowls. Also, the exh port's match w/ the exhaust manifold was consistently poor - actually the worst I've seen on a modern engine. I think these two areas can be improved by most folks as long as they're cautious not to nick the valve seats, envision which direction the air is flowing, & keep conservative in only removing material where you can see a clear benefit.
Playing devil's advocate, is there any concern about the valve edges being more exposed to heat? Perhaps they're also an aftermarket valve of better materials?
I don't see how that could happen, if you use the right material, it will last. Also remember, diesels don't run that hot, look at gas engines running huge valves,:thumbsup:
Not sure what hot is, but diesel combustion chamber temps can reach upwards of 3,000 df...
Not sure how that compares with gassers, but sounds hot to me![]()
