ak diesel driver
6.5 driver
someone needs a db2 4911
Getting the injection pump to fit (it's absolutely massive) and getting the firing order right is the easy part. The hard part is getting the engine to survive, remember the stock pistons are castand that's not the worst part.
Getting something like that made as a bolt-on is something I would do, but there isn't any market for it, as not many people would want to spend about $6000 to just get a pump on their engine, plus the cost of the more expensive upgrades that would be mandatory.
I've got a 8V92T right in front of me and I have no idea what on earth you are talking about. It has a roots blower in the Vee that is fed by a giant turbo suspended over the engine.
I believe he means one of Detroit's new designs. Think it's the DD16. They've added an axial turbine (connected mechanically directly to the flywheel) onto the engine's turbocharger exh outlet. Looks like the idea is to extract more of the heat energy still left in the exhaust stream & mechanically add that axial turbine's power output back directly to the flywheel.
