Woody35
Active Member
i thought the point of compound turbos is to spool up quicker without getting rid of the larger turbo. allows you to have good performance on the top end and good low end power too. something big single trubos do not offer
Some sequential setups are also done to split up the overall pressure ratio (boost) increase btwn 2 turbos........
I have no factual information to contribute to this discussion, but my mind loves to play around with overcomplicated things like this. Its ramblings also included an idea about a small supercharger for the low end with a turbo for the top end. Probably a totally moronic idea if you start to look at it, but kinda fun also..
edit:
Here's a schematic of one twin turbo aplication I found..
How about a belt driven turbo for the small one.
Glad to see I'm not the only one having the supercharger/turbo combo idea, maybe it's not all that far fetched anyway. I guess it's all in the numbers if one takes a little time to look at it. I don't know how much airflow is needed at a certain desired power rating at a given rpm. Where the "crossover" to turbo operation need to be. And how the belt drive and air "plumbing" would work out. But if one had time/energy/funds to do such a thing it would've been fun just for the sake of having done it!
we need to get a engine design engineer on this forum
