ryridesmotox
What? no individual tire pressure sensor?  I'm a bit disappointed.  With all that instrumentation in their it must feel like flying a plane.  It's nice to know what your truck is doing.
Let's see, just for the sake of argument-
The question remains, how long will it last? If you're building a quarter-mile rig it's irrelevant. For those of us looking for longevity and pulling heavy up long hills, my money is on post turbo injection.
- Industrial steam turbine users will spend hundreds of thousands of dollars to make sure the condensate in the steam piping does not get to the turbine.
 - The prop blades on my (high rpm) sport plane spin up to 2800 rpm, turbo props run about 2000, the compressor in your turbo charger runs upwards of 100,000 rpm
 - Look at a prop on a seaplane some time to see what water does at blade tip speeds of only 1100 fps (90" prop at 2800 rpm)
 - water drops, even very fine ones, will erode a turbine compressor wheel.
 - If you consider your compressor wheel to be a replacement item then this design is okay.
Mike
One gauge??
ScanGauge IIWhat's that digital read out on your steering column?
Golly I sure hope you aren't using water from the beach batman. Water won't harm the metal unless its at a ridiculously high pressure. I think a water jet metal cutter runs at like 30-40,000 psi or something crazy like that. Planes run in rain storms and a turbo probably doesn't spool much faster than a metal turboprop plane propeller at full RPM. Plus in rain there are small particulates like sodium, carbon and acid crap. I'm pretty sure most WMI systems call for distilled or highly purified water. Like buddy said no one has shown any early failure... YET
just my 2 cents. I will be going with WMI pre-turbo 3 nozzle setup next spring.
here in Surrey BC we have pretty good quality water. sandblasting was a figure of speech for lack of better wording. I still think water, no matter how pure will eat away at blades spinning at 100,000 rpm's. for the sake of argument going post turbo will allow for an intercooler in the future. if you go pre-turbo i'd think water will condense in an intercooler setting yourself up for a catastrophic engine failure if that water ever makes it to the engine. Ed
So preturbo I wouldnt trust a home brew setup, perhaps the setup in MaxxTorque with 4 tiny foggers.
Well what did it say gugru?:drool5:
Pre-turbo is the only way that I would trust a homebrew setup. If you don't know how to run a calculator and psychometric charts, then you just angle the intake pipe upward toward the turbo and keep the nozzle back at least 12 inches from the impeller. Any excess water will condense and run back out the pipe.
Would you rather risk destroying an engine or a turbo? Injecting too much water post-turbo is an engine waiting to be changed...
Regards,
