Goldsburg
Diesel Tinkerer
...The flowrate spec is useful because you want an IC that does not cause excess restriction at the highest airflows your 6.5 will see...
With that being said, an intercooler that provides little restriction will not be as efficient. This is because the intercooler has to up the air speed to turbulent flow so as to get good "scrubbing" of the air to the interior surfaces of the cooler. If the air is not turbulent, then a boundary layer can form and efficiency will suffer.
I would recommend sizing for 2.0 to 2.5 PSI max drop at full tilt (max fuel max RPM). This should equate to approximate 1 to 1.5 PSI drop when towing hard. In other words, cram the largest IC into the space that you have between the front frame rails, tilt it on a 30deg angle, and call it good. :smile5:
Regards,
