Acronyms "What you talking about"
Turbine Doc
Just Another Diesel Guy
Gautier, Ms./Anywhere Southern USA
A lot of acronyms used on the forums, the 6.5 is no different, here are some of the common ones, add to the list as you think of them:
PMD/FSD = same device Pump Mounted Driver (when installed on IP) or Fuel Solenoid Driver (when removed from IP) electronic device controls operation of fuel solenoid.
IP = Injection Pump
LP = low pressure or lift pump depending on users context
HP = high pressure, also can be Hp=horsepower depending on contex
6.5 LTD = 6.5 litre turbo diesel 6.5L= approx 396 CID cubic inch displacement
CDR= crankcase depression regulator "tuna can" controls crankcase pressure vents to turbo inlet
EGR= Exhaust gas regulation valve on emission engines center rear of inlet
L56= "emissions engine" usually at 1/2 T truck or some LD frame 3/4Ts (S engine 8th VIN digit code)
L65= non emission HD truck engine (F engine 8th VIN digit code)
LD/HD= light or heavy duty frame, HD frame and suspension a little "beefier" weigh more, heavier tow/load capacity. Check RPO codes HD is usually L65 code
RPO= regular production options ??? list inbyour glove box of options your truck was delivered with
CAT= catalytic converter slang generally L56 trucks have this
WG= waste gate, flapper in turbos outlet that aids in spool up of turbo to reduce lag time until turbo camn make efficient boost
PCM= powertrain control module brain/computer that runs it all.
OPS= oil pressure switch
WIF= water in fuel
SES= service engine soon/check engine in GM manual this is MIL malfunction indicator lite
APP= accellerator pedal position, electronic module on go pedal that talks to the PCM for more or less fuel from the IP
OBD I or II= on board diagnostic generation I or II, in 1996 Congress mandated all US mfg use common diagnostic port and naming conventions OBDII trucks have electronic IP and require scan tool to read codes and perform diagnostic tests.
MAP= manifold absolute pressure mounted on upper intake gives Boost pressure input to PCM in OBD II L65 also provides baro conditions to PCM at start up,
Baro= barometric sensor in OBDI trucks mounted on firewall provides baro input to PCM, in L56 OBD II it also serves as the EGR feedback mechanism, not used in L65 OBDII which gets its baro from MAP (see MAP), both look the same but are keyed to only accept correct harness connection, have to make sure you get the correct sensor.
MAF= mass air flow flow sensor used in L56 to tell PCM how much flow in turbo inlet used to help calculate proper EGR flow
VSS= vehicle speed sensor
IAT= inlet air temp gives input to PCM how hot post turbo air is
ECT= engine coolant temp
IC= intercooler or aftercooler air to air heat exchanger that drops post turbo compressed air temp
WMI= water mist injection another way to cool turbo air using fine water mist
DTC= diagnostic trouble code
WGDC = waste gate duty cycle, The percentage of waste gate caluculated by the PCM that determines boost levels.
EGT = exhaust gas tempatures. When you turn your WGDC up you should watch your EGT's 1100-1200*F max. allowable tempatures.
EBP =exhaust back pressure is what turns the turbine.
TSM = Timing stepper motor. tsm advances the optical on the cam ring.
CTS = Coolant tempature sensor. It's in the way when you try to loosen the pump bolts
IIRC= If I Remember Correctly, which I sometimes don't so heavy emphasis on 1str word IF
General Chat acronyms:
BBIAB = Be back in a bit
BRB = Be right back
BTW = By the way
FOS = Full of S**t
FWIW = For what it's worth
IIRC = If I Recall Correctly
IMHO = In my honest opinion OR In my Honest opinion
IMO = In my opinion
JMO = Just my opinion
LMAO = Laughing my A$$ Off
LOL = Laughing out loud
N/A = Not applicable, not available can also mean naturally aspirated
NFG = No F'n good
POS = Piece of S**t
ROFLMAO = Rolling on the Floor laughing my A$$ off.
RTFM = Read the f***in manual
STFU = Shut the f*** up
TIA = Thanks in advance
TTYL = Talk to you later
TY = Thank you
YW = Your welcome
Truck Acronyms and abbreviations:
#1 = #1 Diesel Fuel (winter diesel fuel)
#2 = #2 Diesel Fuel
APP = Accelerator Pedal Position
BCM = Body control module. The module that controls various body related functions such as power windows, power locks, interior lights etc.
BOV = Blow off valve
CAC = Charge air cooler otherwise called Intercooler
CAT = catalytic converter
CC = Crew Cab
CEL = check engine light
CP3 = Duramax High pressure injection pump
CTD = Cummins Turbo Diesel
DA or D/A = Duramax and Allison combination
DHRA = Diesel Hot Rod association
DRL = Daytime running lights
DRW = Dual rear wheels
DTC = Diagnostic Trouble code
Dyno = Dynamometer
EC = Extended Cab
ECM = Engine control module
ECT = Engine Coolan Temperature
EGR = Exhaust Gas Recirculation
EGT = Exhaust Gas Temperature
G80 = Gm's RPO code for the rear locking differential in our truck
GN = Goose neck
HD = Heavy Duty
HP = Horsepower or High pressure
IAT = Intake Air Temperature
IC = Intercooler
IP = Injection pump
J/A = Edge Juice and Attitude
LB = Long Box
LP = Lift Pump or Low pressure
MAP = Manifold Absolute Pressure sensor
MAF= Mass Airflow sensor
MIL = Malfunction Indicator Lamp/Light
N20 = Nitrous Oxide
NA = Naturally Aspirated, can also mean not applicable or not available
NOS = Manufacturer of Nitrous Oxide systems (quite often mistaking used to describe Nitrous Oxide)
NSBU = Neutral safety backup sensor.
OBDII = Standard for diagnostic codes
Odo = Odometer
OEM = Original Equipment Manufacturer
PCV = Postive Crankcase Ventilation
PS = Power stroke or Power steering
PSD = Power stroke Diesel
PTO = Power take off
PYO = GM's RPO code for the aluminum wheels found on our trucks
QC = Quad Cab
RC = Regular Cab
RPO = Regular Production Options
RS = Remote start
RT = Reaction time
SB = Short Box
SES (light) = Service Engine Soon (light)
SRW = Single rear wheels
SS = Stainless steel
TC = Torque converter
TCM = Transmission control module
TIT = Turbine Inlet Temperature
Tech II = GM's tool used to test, diagnose and reprogram the various computers in our truck
TQ = Torque
VIN = Vehicle Identification Number or Serial number
VSS = Vehicle speed sensor
WG = Waste Gate
WIF = Water in Fuel
WOT = Wide open throttle
DLC = Data Link Connector also sometimes called ALDL
J/K or JK - Just Kidding - Important to use when inserting humor, as sometimes people get pretty upset because they don't see that you're using satire or irony or just telling a bad joke.
-Rob :)
HP= High pressure- Horsepower :)
It must be a busy day at the yard Tim.
I'll ammend it to include tha but in turbine world and common rail Diesel HP is indeed both meanings I guess we could ammend our reference to proper terminology as SHP or BHP shaft or brake horsepower, then throw in FWHP for flywheel power or RWHP for rear wheel power
I hate to nit pick. but IMHO, you repeated yourself. Shouldn't in be 'in my humble opinion' for the second one? I"'m sure there will be a few more to add.
well I did borrow some from my old post from the other site I'll purge the repeaters later or IMHO (honest) or (humble) are interchangeable IMHO though :D and could be used as separate acronyms that are synonymns
ABS= Anti lock Brake System
APP= Accellerator Pedal Position, electronic module on go pedal that talks to the PCM for more or less fuel from the IP
ATA= Air To Air IC that uses air as cooling medium to cool post turbo charge air
ATT=A Team Turbo, non wastegated high flow turbo patterned after the Mitsubishi TD07-22A turbo, "pet project" of DTR members named by moderator Jifaire citing old TV show A-Team, who's motto was "Just love it when a plan comes together".
CAT= CATalytic converter slang generally L56 trucks have this
CDR= Crankcase Depression Regulator "tuna can" controls crankcase pressure vents to turbo inlet
CPS = Crankshaft Position Sensor
CTME= closure time on DS4 IPs fuel solenoid
DB2= 2 plunger mechanical IP used on 6.2s & early 6.5s
DS4= 4 plunger electronic IPs used on 93+ 6.5s
DVM or DMM = digital voltmeter or mulitmeter
EFI= electronic fuel injection, modern 6.5s late 93+ use "fly by wire" electronic engine speed management/fuel delivery with electronic vs mechanical IP
EGR= Exhaust gas recirculation valve on emission engines center rear of inlet
EPROM = erasable programmable read only memory; AKA chips (brains) in OBD1 PCMs
FSO/ESO = Fuel/Engine Shut-Off Solenoid
FSU = fuel sending unit
FTB= "Feed The Beast" a mod to increase fuel flow & feeding to the engine, by modifying fuel filter manager & IP inlet for max fuel flow, idea cooked up by TD one day pondering a low EGT at WOT climbing a hill with heavy loaded trailer.
HX= abbreviaton for Holset company as in HX-35 turbo, also HY turbos
IIRC= If I Remember Correctly, which I sometimes don't so heavy emphasis on 1st word IF
IP = Injection Pump
LP = liquid propane when talking fumigation
MAP= manifold absolute pressure mounted on upper intake gives boost pressure input to PCM; in OBD II L65s it also provides baro conditions to PCM at start up,
OPS= oil pressure switch sometimes seen as OPSU oil pressure sending unit
OS = Optical Sensor
PCM= powertrain control module brain/computer that runs it all, sometimes also seen as ECM engine control module
Reflash= reprogrammed PCM (performance tune) in OBD-II, similar to "chip" in OBD-I where PROM is swapped out for performance program.
RPO= regular production options ??? list in your glove box of options your truck was delivered with
STS= service throttle soon
TCC = Torque Converter Clutch
TD= Turbo Diesel, or in some contexts Turbine Doc (6.5 enthusiast) a monaker picked up as "healer" of ailing jet turbine engines for 28 years before moving to Diesel locomotive "healing" in 2nd career life.
TDCO = Top Dead Center Offset
TDI= Turbo Diesel Intercooled most times used as a reference for VW's Diesel engine or car
TPS = throttle position sensor, mechanical IPs 6.2/6.5 use TPS on side of IP to give PCM input of the throttle.
TTY = Torque to yield, torque procedure where a fastener is run down to a torque value and once that is met then final torque would be represented say 45'ft +90 deg. so run down til torque wrench bottoms at 45, then final tun fastener 90 degrees more, or sometimes you bott then back off X degrees, 6.2/6.5 head bolts are most often discussed as TTY bolts.
Turbo=short for turbo charger, exhaust driven compressor feeds force air to the engine giving it more grunt, GM turbos GM-3, GM-4, GM-5, GM-8 are common models, sometimes listed as GM-X with X replacing the final variable designator for the GM turbo family. GM-8 last production model for the 6.5, best of the GM turbos, good turbo for that application suffers restrictive flows at higher power, sometimes replaced by the ATT.
VSSB= vehicle speed sensor buffer
WIF= water in fuel
WOT= wide open throttle, max fuel flow command from the APP, or "pedal to the metal/floor" on non EFI trucks with cable/accelerator on a mechanical IP
WTA= water to air, a IC that uses recirculated water to cool post turbo charge air
TD edit Matt I tweaked it some more Thanks for the assist
CPS = crankshaft position sensor
OS = Optical Sensor
I Added buddies into the list, Just cut and paste my post into your original post for simplicity. I don't need credit.
TCC is missing. I'm not sure exactly what it stands for.
there is a edit time limit for non staff, this is to curtail those "hit & run posters" that will paste a troll type post & get a rukus started, then change their post in the middle of the fray acting "innocent" of being the instigator of the rukus.
Copy paste into a new post, then you'll reset the timer and I of one of the other mods can delete the one you wanted to edit but could not. Or shoot us a PM and we can make the changes for you, whichever works best for you, we generally don't edit a post, but since this one is to put together a reference material post we'll use a little more latitude for our do not edit posts rule we mods work to.
PS I added last ones Buddy contributed, plus some more I thought needed to be there.
Keep em coming folks
