How To: 99-06(07 Classic) Regular Cab Long Overhead Console Install & Information
Discussion in 'Do It Yourself Articles - How To's & Product Revie' started by 88gmctruck, Dec 5, 2009.
  1. 88gmctruck
    88gmctruck 02GMCtruck
    1,973
    170
    Mar 16, 2009
    Auburn, Wa
    This how-to applies specifically to 99-06(07 Classic) regular cab trucks.
    If you would like to install a console in an 88-98 (99 Classic) regular cab the general procedure is the same, except those trucks have a double walled roof and do not require the domelight relocation, however require cutting the back tabs off the console or cutting holes in the roof for the tabs.
    If you would like to install a console into any extended or crew cab truck the general procedure is the same, except those trucks have the necessary supports to install the console without modification.
    This is the procedure I used to install a long overhead console from a 99 Yukon Denali into my 2002 regular cab. The regular cab trucks are interesting as they do not have a double walled roof. From what I hear, extended and crew cabs do have the double walled roof, which simplifies the process as they were designed to have the console so the slots for mounting the rear of the console are present.
    Tools:
    Razor Knife
    Screwdriver (torx, flat & Phillips)
    Drill
    Long screw
    Wire crimpers/cutters OR soldier gun
    Wire
    Tape OR Heat shrink
    I suggest wearing latex gloves for a lot of this project. The light grey headliner attracts dirt easily. First remove all the stuff attached to the headliner. The sun visors screw off, A (front) pillars and back window trim pull off, the B (rear) pillars have screws under the window trim and then pull off, dome light, grab handle and coat hooks all come apart and unclip. Before pulling it down, mark where the dome light opening is (for measurement purposes later).
    [​IMG]
    [​IMG]
    Take the headliner down. The driver's side has a magnet holding it up. A note, the glue from my windshield was stuck to the front so I gently pulled it apart from there.
    [​IMG]
    See how there is no double wall? Next step is to trace the shape of the dome light opening on something, so if you want you can relocated it behind the console. While your back there, pull the dome light wires from the headliner back a bit, as your dome light will be moved and you don't want to cut a wire.
    [​IMG]
    [​IMG]
    Now, measure from the square hole (the one that sticks down a little, to the marking where the dome light was. This will tell you where to cut the headliner for the front of the console. Also, measure from the back of the headliner past the thicker support part. This will be used later for the dome light relocation. Write these numbers down!!!
    [​IMG]
    Now put your headliner back up. I put the grab handle and coat hooks back to support it. Mark the area you need to cut. I choose to remove as little material as possible to help keep the rigidity of the headliner.
    [​IMG]
    [​IMG]
    Next drill a hole in front of the square hole. be sure you don't hit the outter skin of the roof when doing so. This is where the front screw mounts for your console. I used a "J" clip like factory.
    [​IMG]
    (Extended/Crew Cabs Skip this step) Now enlarge the dome light hole so your console tabs fit inside it. As there is no metal above the headliner, it will be supporting the weight of the console. The backboard isn't thick enough for the tabs, so find something to put up there. I used a piece of baseboard trim (it tapers slightly) and made it extend well past the sides of the hole. I also suggest attaching it with some adhesive.
    [​IMG]
    At this point you should be able to test fit the console. It won't quite go all the way up to the headliner yet, as the area behind the map lights hit. So you have to cut another hole out. Just press the console firmly into the headliner and you should see where it hits.
    [​IMG]
    [​IMG]
    Now for the last step. Cut out your stencil for the dome light. Take your earlier measurement and go just a little longer and mark for your dome light. Start out small and trim as needed. Plug the light back in and test!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Wiring Info:
    Orange: 12V + constant
    Black: - ground
    White (Homelink console only): Dimmed dash lights (can pick this up at radio or IP cluster).
    You can connect to power at the dome light, but you will need to find your own ground as the dome light is a switched ground.
    If you want your map lights to come on with your dome lights yet work individually as well, it's a bit tricky. You have to change the lights to a switched ground
    1. Cut the factory wires where they split (both orange and black). You will want to swap the leads going to the map lights with each other (this will make it so the map lights are switched by ground just as the dome lamp).
    2. Then you will run a wire from the dome light ground (which is white at the dome light) to your console.
    3. Splice a Diode between each switch and each light, and connect both to the white lead. Be sure to keep the diodes leads separated on the console side going to the map lights. Follow the package directions as a diode only allows current flow through one way.
    4. If everything works correctly, both map lights will turn on with the dome lights, and work individually with the button. If you have the diode wired the wrong way the switches will turn the dome light on but the dome light won't turn the map lights on.
    If your console came like mine (with rear AC or Heat controls) you can replace them with a blank panel, part number 15737207 and runs about $16 at the dealer.
    Pictures of the finished product (with Denali DIC installed)
    [​IMG]
    [​IMG]
    [​IMG]
    Information on overhead consoles:
    GMT400 trucks/SUVs used two styles of overhead consoles; a truck and an suv style, both long. The truck style has a smaller opening in the front (same as the S-10s) and is much harder to find. The SUVs had a larger opening for HVAC contols. There are no options nor provisions for an OH console in a regular cab.
    GMT800 trucks/SUVs used two consoles as well; a short console with only a pocket and maplights, and an extremely simlar long console as the GMT400 SUV console. The short console is the most common, and is available in all models. The long console is not available in regular cabs.
    S-Series & Astro/Savana consoles will not fit without modification to them, the rooflines are different. There are short, long, and super long consoles from these vehicles.
    GMT400 Truck console
    This is the console in my 88 Sierra. It's the smaller opening style (shared with the S-10s). It has the compass/temp unit from an S-10 installed in it.
    [​IMG]
    [​IMG]
    GMT400 SUV console / GMT800 long console.
    This is the console in my 02 Sierra. It's the large opening style, and is actually from a GMT400 SUV. The only difference is there is a small gap on the back where it meets the headliner (which you can't see in the regular cab). I have a Denali Driver Information Center custom mounted in mine.
    [​IMG]
    [​IMG]
    GMT800 Short console variants (first is for a sunroof, second is standard)
    [​IMG]
    [​IMG]
    Color breakdowns:
    GMT400 colors range 92-94 and 95-98 (00c). The 92-94 consoles also had a lighter metallic silver color for the plastic, as opposed to the grey color more commonly seen in 95-98 (00c) trucks. See the difference in the door on the blue console? Both of these were 92-94 consoles from suburbans.
    [​IMG]
    GM800 colors range 99-02 and 03-06 (07c). Some 99-02 colors are interchangeable with 95-98 (00c) such as the medium grey in my 02.
  2. 07HDClassic
    07HDClassic New Member
    271
    0
    Feb 15, 2009
    Poulsbo/Pullman, WA
    Nice post. I like the last 4 pictures... all of my spare consoles
  3. 88gmctruck
    1,973
    170
    Mar 16, 2009
    Auburn, Wa
    Yup, your OEM one, the esky one and the two suburban parts consoles.
    Still in the process of fixing up that blue one for Ted.
  4. DieselCash
    DieselCash Trust but, verify Staff Member Moderator
    6,359
    133
    May 29, 2008
    Salado, Texas
    Do you know how to change out the light bulbs for the map lights on the 92 - 94 console?
    I had mine apart but could not figure it out.
  5. 88gmctruck
    1,973
    170
    Mar 16, 2009
    Auburn, Wa
    Pop the lense off, and get the silver reflector out. They are just a 194 bulb.
  6. 07HDClassic
    271
    0
    Feb 15, 2009
    Poulsbo/Pullman, WA
    It's amazing how Dave can modify overhead consoles into almost anything. Dave installed my long console in my 07 while I was in the bathroom.
    Dave, we still need to modify that suburban overhead console for Caleb's Jeep
  7. 88gmctruck
    1,973
    170
    Mar 16, 2009
    Auburn, Wa
    I thought the one for Caleb was from a Blazer/Jimmy? And yes, we still need to do that.
  8. 07HDClassic
    271
    0
    Feb 15, 2009
    Poulsbo/Pullman, WA
    Oh yeah, the really big console, that's right. We can use th console out of my Jeep as a template.
  9. ak diesel driver
    ak diesel driver 6.5 driver
    12,758
    2,762
    Feb 7, 2009
    alaska
    I wonder how hard it would be to use the driver info center and get the mpg part to work?
  10. 88gmctruck
    1,973
    170
    Mar 16, 2009
    Auburn, Wa
    It's very simple. I have the Denali version fully wired up in my 02 (which is custom mounted in my console, they were actually in the center console below the dash in 01-02 Denali and 02 Escalades). The S-10 version has a few less options than the Denali computer.
    Both will work on any OBDII truck, they are about a 7 wire hookup (power, keyed power, ground, dash lights, VSS signal and Class 2 data)
  11. ManiacMotorsports
    ManiacMotorsports New Member
    3
    0
    Jan 12, 2010
    I could really use some help here on overhead console issues from an s10, and it sounds like you guys have got a lot of experiance with these. ok so i installed it in my '98 cherokee, but now i have concerns that the compass portion is bad, compass doesn't change direction. (and it will not calibrate) I did not hook up the VSS (cause i had no clue what to do with it in a cherokee) but my impression is that portion is only used to make the thermometer not change when stopped. HELP PLEASE....
  12. 88gmctruck
    1,973
    170
    Mar 16, 2009
    Auburn, Wa
    I had the same problem, and it sounds like your compass is bad.
  13. ManiacMotorsports
    3
    0
    Jan 12, 2010
    ok thanks much thats all i needed to know, i'll get a new one from the scrapyard i got this one from tomorrow, was just curious if it had to do with me not hooking the VSS up
  14. ManiacMotorsports
    3
    0
    Jan 12, 2010
    Ok well i apologize for being so needy on this install but you seem to be very knowledgeable on these consoles so i could really use a little help, so i got my replacement console, but my new one is the type with the mpg and homelink in it. I'm sure i could manage to figure out the homelink portion, but i have no clue where to get the signals (the vss and the class 2 data??) from on my Cherokee to get the mpg portion to work.... any help you could give me would be infinitely appreciated...thank you in advance for all your help
    -Travis
  15. wprecanico
    wprecanico New Member
    3
    0
    Jun 11, 2010
    Russell, Massachusetts
    Overhead console for 1993 Chevy Silverado Ext. Cab
    Nice post!
    I see it's been a while for other postings, but I'm curious if I can put an overhead console in my '93. I like the idea of a Denali DIC as well. Is it possible to do that? Should I be looking for anything in particular when I'm gathering parts?
    Thanks for any information you can share.
    - Wayne
  16. 88gmctruck
    1,973
    170
    Mar 16, 2009
    Auburn, Wa
    It's all explained in the original post. if your 93 is an extended cab you just have to cut your headliner and install a screw in the front. Regular cabs are a little are different as they don't have the mounting holes in the back, so you'll have to cut holes in the roof or cut the tab off the console and mount it a different way.
    The denali DIC along with the full function s-series computer is only compatible with obd2 trucks.
  17. wprecanico
    3
    0
    Jun 11, 2010
    Thanks for the reply. I should have been more clear. The original post was excellent for installing the console. I should have asked more specifically about the DIC. Are there any other options that I might be able to put up there? I'm thinking along the lines of a clock, temp, or compass.
    - Wayne
  18. 88gmctruck
    1,973
    170
    Mar 16, 2009
    Auburn, Wa
    If you look at the picture of my red truck towards the end of the post, I have a compass temp unit from an s-series. that is about the only option you have for factory, so if you went that route you'd need a small opening console and the computer and temp sensor.
  19. wprecanico
    3
    0
    Jun 11, 2010
    Okay, I'll look around and see if I can find anything. Thanks for the idea. I was originally looking for a center floor console and saw your post. Started me in a different direction.
    - Wayne
  20. Truckboss223
    Truckboss223 New Member
    1
    0
    Aug 25, 2010
    Island Park, NY
    I have a 98 2dr Tahoe with no rear heat (see Attached Picture) which i put my switch panel in for all my emergency lights. I just picked up a used overhead console from ebay for a 99 suburban with the 3 buttons for the garage doors. I want to hook up the garage door openers so they work. I read the above on which wire goes to what but dont understand where the white wire goes ? can you go into a little more detail about where the white wire goes and its volt requirements
Share This Page
