Has anyone actually installed an Optimizer 6500
Discussion in 'GM 6.5 Diesel Engines' started by TurboTahoe, Jan 18, 2010.
  1. TurboTahoe
    TurboTahoe Recruit
    790
    4
    May 6, 2008
    There have been so many glowing reports of this new progeny of the 6.5, that I have to wonder if anyone has actually ordered and installed a long block? I notice that vendors like 65engineparts dot com actually claim to stock them for around $4500, and that is about the price from DieselDepot for a rebuild.
    So... how about it? Did anyone drop one of these bad boys in, and was it worth it?
    -Rob :)
  2. MBBOB
    MBBOB Member
    35
    0
    Aug 7, 2008
    Conneaut Lake, PA
    I installed a new AMG/GEP Optimizer long block, factory fresh from Franklin Ohio. Unless something has changed, the only authorized vendors for this engine are W.W. Williams and Penninsular Diesel. The engine was $5,750.00 plus $200.00 shipping. There were many threads on the other site about GEP long and short blocks available everwhere.
    As I said, unless something has changed in the last year, if it did not come from Franklin, Ohio, it is not an AMG /GEP Optimizer, it is a Chinese knock-off.
    If you want the contact info at W.W. Williams let me know, it was the easiest and most professional transaction I ever had.
  3. TurboTahoe
    TurboTahoe Recruit
    790
    4
    May 6, 2008
    Yes, I absolutely would like the contact at W.W. Williams. Please PM me.
    More importantly, give us details on the installation AND the performance. How's she rocking?
    -Rob :)
  4. chickenhunterbob
    chickenhunterbob New Member
    65
    0
    Nov 17, 2008
    As far as I know any long block purchased from GM dealers (and umpteen others selleers of GEP engines) since late 2001 would be an optimizer 6500. It's the GEP name for the GM 6.5 diesel.
  5. MBBOB
    MBBOB Member
    35
    0
    Aug 7, 2008
    Conneaut Lake, PA
    Ron Taylor
    Defense Business Development
    W.W.Williams
    Consider It Done
    313.584.6150 Ext.337
    313.584.1444 Fax
    800.468.6332 Toll Free
    mailto:rtaylor@wwwilliams.com
    Ron was a great guy to deal with, it shipped when he said it would, arrived when he said it would, followed up to see if delivery was OK. He said mine should have a forged steel crankshaft as they had just changed from cast ones.
    It came in a full crate, with new block heater, balancer, oil and filter. Install was smooth. I marked a reference point on the pump and installed it as close on the new engine as possible, fired right up and was close enough until I had it set to -1.50. She has been running great for the last 10K!
    My only complaint is I lost 2 mpg with the new engins and can't figure out why.
  6. Big T
    Big T Well-Known Member
    2,894
    280
    Sep 25, 2009
    Fullerton, CA
    Still too new, the mileage will get better with break in.
  7. ak diesel driver
    ak diesel driver 6.5 driver
    11,475
    981
    Feb 7, 2009
    alaska
    Probably not broke in all the way yet.
  8. Woody35
    Woody35 Active Member
    1,021
    1
    Apr 2, 2009
    Chi-Town Suburbs
    lower compression?
  9. TurboTahoe
    TurboTahoe Recruit
    790
    4
    May 6, 2008
    I don't think so. I think that the GEP blocks are still at 21:1 compression. Anyone know for sure?
    -Rob :)
  10. Woody35
    1,021
    1
    Apr 2, 2009
    Chi-Town Suburbs
    maybe thats the p400 im thinking of. its pretty confusing what is the difference between these two engines.
  11. SSdiesel sells them too....$6500.00 including shipping.
  12. TurboTahoe
    TurboTahoe Recruit
    790
    4
    May 6, 2008
  13. Woody35
    1,021
    1
    Apr 2, 2009
    Chi-Town Suburbs
    is that still a 6.5? it says 400 CID
  14. Big T
    2,894
    280
    Sep 25, 2009
    Fullerton, CA
    250 hp / 550 ft lbs of torque, forged crank.....I'm there when one of my GM versions goes.:eek:
  15. SmithvilleD
    SmithvilleD Active Member
    907
    104
    Mar 2, 2009
    Smithville, MO
    I think I found a little something to clear the Optimizer 6500 / P400 question.
    Just reviewed the thread on The Diesel Page written by the guy that put a P400 in a GMT400 dually (w/ the custom fab work to come up w/ an oil pan that fit the pickup frame, etc.)
    His text says that the P400 is a redesign of what was the Optimizer 6500. And there appears to be clear differences. Forged crank etc. Looks like the key to look for is the "P400" casting mark. The text says he got it from WW Williams & mentions the name Ron Townsend (same first name anyhow). Says it's 20.2:1
    There's even a bit of feedback on possible boost levels for max torque, that appears to have come from AMG/GEP engineers & was retracted. Possibly engineers answered before considering folks putting it in pickups might not have enough engine cooling system, or charge air cooling to safely support the initial suggestion of 28 psi boost for max recommended torque levels. Very interesting stuff to hear any OEM engineer's thoughts; even if caution & common-sense backed off on the earlier statement.
    Somebody, at least off-hand thinks w/ all the supporting equipment, it will handle 28 psi. Obviously not to be taken as written in stone, but still interesting.
    Check out the pic in this link of an engine setting in the crate, getting ready to hang it from the hoist. You can see the "P400" casting mark on the left bank rear/vert surface just below the deck.
    http://www.thedieselpageforums.com/tdpforum/showthread.php?t=31870
    Maybe it needs to be the P400 designation to have the redesigned, stout looking ladder-tied mains & forged crank?
    Maybe the Optimizer name was carried over? Who knows? No doubt something to study well before parting w/ serious coin. If there was significant inventory of the earlier Optimizer 6500, folks holding the paper on that inventory will be most interested in selling that inventory.
  16. Woody35
    1,021
    1
    Apr 2, 2009
    Chi-Town Suburbs
    the engineer at the franklin ohio plant that builds these says these p400s are safe up to 28 psi at 20.2:1 comp ratio. thats a strong engine
  17. SmithvilleD
    907
    104
    Mar 2, 2009
    Smithville, MO
    Don't know if it means anything, but AM General's website still shows the old specs on their website, for the Optimizer 6500 name - cast crank, 205/440 trq/hp rating, etc.
    http://www.amgeneral.com/vehicles/gep/specifications.php
    Don't know if it's just the website isn't updated? Or maybe there's inventory of 2 different crate engines being sold?
  18. SmithvilleD
    907
    104
    Mar 2, 2009
    Smithville, MO
    I love this Ron guy's auto-signature line:
    "Consider it Done"
    Very nice!
  19. TurboTahoe
    TurboTahoe Recruit
    790
    4
    May 6, 2008
    I'm pretty sure the mods will delete the link to that other forum, so here are the pics....
    -Rob :)
Share This Page
