  2. Texas and Louisiana needs your help!
    We have members affected with this storm.
    Update: Crowdfunding Link by JJ Watt of the Houston Texans: Go Here
    Dismiss Notice
Can I run 285/75/16 tires on my K1500
Discussion in 'Steering, Suspension and Wheels' started by fonecop1, May 13, 2010.
  1. fonecop1
    fonecop1 New Member
    188
    0
    Dec 21, 2008
    I am thinking about putting a set of 285/75/16 Cooper Discover ST tires on my 95 K1500. Is anybody running 285's on their K1500? Any problems with clearance?
    Thx,
    Bob
  2. Woody35
    Woody35 Active Member
    1,021
    1
    Apr 2, 2009
    Chi-Town Suburbs
    probably need to crank the torsion bars a bit. kid from school runs same tires on a 2500 light duty and he says they dont rub and he didnt crank the t-bars but i find that hard to beleive since my 265s rub in 4wd
  3. tanman_2006
    tanman_2006 Just a farm kid...
    5,464
    461
    Feb 15, 2010
    Seiling, Oklahoma
    My cousin did his w/o cranking and it didn't rub until he went off road then the smashed the top of the fenders when it flexed too much. Now it is cranked but not all the way and is fine.
  4. buddy
    buddy Active Member
    Crankme69 just put 275/55/20s in his 95 C1500 and they rubbed some and would hit the fender when suspension traveled.
    However his wheels are 0 offset, just like the factory wheels I think. Your wheels will be wider and taller, so I think you'll have more issues. The rubbing would probably been solved with -12mm offset (1/2") or maybe even just some 1/4" wheel spacers. Some coil spacers will solve the suspension travel issue. When putting that big of wheels on you typically need negative offset wheels or spacers, and some type of suspension lift, but your 4x4 likely has some more lift than a 2WD.
    You will also take a LOT of torque away that you can put to the ground, and dont think youll like the result.
  5. tanman_2006
    5,464
    461
    Feb 15, 2010
    Seiling, Oklahoma
    I think unless you have 4.10:1 gears you will get bogged down too much. 265/75's are fine or if you are looking wider a 32x10 would be an improvement.
  6. buddy
    buddy Active Member
    I agree that 265/75/16 is probably the best choice without messing anything up, or needing modifications.
  7. fonecop1
    fonecop1 New Member
    188
    0
    Dec 21, 2008
    The truck has 3:73's in it. The reason I was gonna go with them is because my Son works at a tire shop and could get a set with 95% tread on them for 1/2 price. I don't want to kill the truck though. The truck is semi retired but I still drive it a few days a week and use it to haul wood, usually the wood is just a couple miles from the house though. Other than the wood hauling all it sees is light duty and highway driving, do you think it will make that much difference for that type of driving?
  8. It most certainly will drop yr final drive ratio down...
    I like how mine turned out...I can cruise on the expressway at 70 now just a tad under 2K on the tach, sweet but I do alot of superslap driving, about 100 miles a day, so it may not be for everyone.
  9. fonecop1
    fonecop1 New Member
    188
    0
    Dec 21, 2008
    The couple of days a week it gets driven is to work and it's an 80 mile round trip to St Louis and back.
  10. That was my incentive...not to mention IMO it looks Bad Arse!
  11. fonecop1
    fonecop1 New Member
    188
    0
    Dec 21, 2008
    They do look good.
  12. buddy
    buddy Active Member
    265/75/16 is a 31.5" tall tire and 245/75 is a 30.3" tire. So its still going to drop the final drive ratio but not require any modifications.
    285/75 is a 32.5" tall tire and would essentially make it feel like a 3.42 geared truck, which would still do OK, thats what I have.
    Crankme started with 235/75/15 tires which are only 28.5" tall, so his dropped down to like 3.3 gears
    However, your truck will still have less power to the ground since the overall height is taller. Its just that your reference right now is how a 3.73 gear feels with a 245/75/16 tire most likely. So relative, a 285/75/16 tire would then feel how a 245/75/16 tire would feel on a 3.42 gears.
    If us that started with 235/75/15 put 285/75/16 on it would be like dropping from 3.73 to 3.25 gears
  13. fonecop1
    fonecop1 New Member
    188
    0
    Dec 21, 2008
    Thanks for that info Buddy. 3:42 don't really scare me, if you would have said 2:73 or something like that it would have been a different story. The truck has 334,000 miles on it and is somewhat tired anyway, I just don't want to bring it way down.
  14. Brooklyn Tow
    Brooklyn Tow 9 11 Never Forget
    3,212
    4
    May 6, 2008
    Brooklyn, NY USA
    CrankMe69 Are those new shoes' on your rig?........They're certainly Nicccce!
    What size are they?
  15. Thanks Louis
    Yup MB Motoring 20x9's wrapped in Falkens 275/55/20's
  16. Woody35
    1,021
    1
    Apr 2, 2009
    Chi-Town Suburbs
    what's their weight rating?
  17. The tire is for light truck, truck & SUV's, here is the Manufacturer's Logo
    Falken Ziex S/TZ-04
    P275/55R20 XL 117H B
  18. john65td
    john65td Addicted to boost
    323
    0
    Jun 9, 2009
    Cassadaga New york
    They won't rub i have my t- bars turned up like 4 or 5 turns and i'm running 35's no rubbin even with flex
  19. tanman_2006
    5,464
    461
    Feb 15, 2010
    Seiling, Oklahoma
    275/55 R20's are ~32inch, so that is equal to 265/75 R16's. I started with 265/75's on my Old 02 GMC and when I put the 275/55 R20's on the speedo nearly the same according to my GPS. I had factory 08 Denali wheels and tires.
  20. handcannon
    handcannon Well-Known Member
    1,744
    87
    Nov 21, 2009
    Albany, OR
    Go to grimmjeeper(dot)com for a gear ratio calculator. Punch in your gear and tire specs, motor RPMs, and speeds driven and see what you get. The site has been a favorite for me to play with gear ratios and tire sizes for my Toyota FJ40. Very informative site.
    Don
Share This Page
