millsroger
AC is full width, trans, engine and PS stack is on drivers side to about half way across, leaves passenger side available for heat exchanger. I live where I need to haul water to underground tank. Normally I use an 86 Ford 350 CS with a 500 gallon tank. This morning I slid the tank to the Chevy and did the run. Also pull a trailer with a 1000 gallon tank. That's a 4000 lb load plus the truck, and a 10000 lb pull. 2000 ft clumb in about two miles on a gravel road in low range. Temps stayed right on the tstat at 85 degrees ambient with AC on. Point is that I think I got some BTU room for the added heat exchanger. Mechanically it's not quite as thick as the combined stack is so will fit nicely. Intercooler is 4.5 x 5.5 x 14 and will sit above the driver's side valve cover. System is rated for 600CFM with a 1 lb drop at max flow. Chart says IAT will hold ambient +15 at 18 psi boost with 1100CFM fan. Way better than I need but I don't trust specs much anymore.
