packratt
Active Member
How in the (*(*& do you manage to break on of the wings the distributor cap screws to off of the distributor?
Was replacing plugs, wires, cap, and rotor on a truck with a 7.4 Vortec I just got. One of the bolts holding the coil bracket on was missing the other had the head mostly ground off, so the coil was bouncing up and down. Managed to get the coil off so I could reach the distributor cap. Removed the back screw front screw was missing. Installed the new rotor. Put cap on and tightened back screw, front screw wouldn't tighten. Dicked around with it for a good while trying to get screw to tighten. Finally removed new cap and got a flashlight so I could see the distributor. Find that the tab was missing.
A new MSD billet distributor is on order, cheaper than getting a new ACDelco.
Funny thing was the truck ran with the distributor cap only fastened on one side.
Any suggestions on how to get the EGR tube to unscrew from the fitting into the intake?
