jrsavoie
Recruit
Toro 220D model 30794 serial 86000
Wiring issues. Previous owner made a
Mess.
Ground cable is disconnected from the battery.
Pulled the 5 or 6 wire plug off the ignition switch.
Between the battery ground post and every pin on the starter plug, there is voltage showing.
Even from the valve cover.
He didn't use proper colors of wires. Makes it harder to trace.
I had pulled the lift pump wire and put it on a toggle switch. First thing I noticed was the lift pump running all of the time.
We've been running like this for quite some time.
I had a brake issue and while waiting for the cable, I opened the control panel to replace the ignition switch - which was hanging in the start position.
I have the schematic, but having trouble following it.
If anyone close is interested, I'd pay good money to have it right.
It really can't be that bad, Im just tired and not thinking.
If he had at least used the correct color wires. It'd be easier to sort out.- I understand that. You use what you have.
I've taken to really avoiding using the wrong color wires. I've bit myself a couple times.
I think he had a mouse issue
www.toro.com
Mess.
Parts – Groundsmaster 220-D | Toro
