Detroit Dan
I wish these posts had a "like" button like Facebook, so we could just click like on comments like Kennys ChrisK comment. Haha
so the 99 stayed home because of a ripped cv boot? I had a ripped boot, clean in two, drove it every day and plowed two seasons with it before it started hinting at making noises. I had spares at home (thanks Joey D!) so I just left it alone. Couldn't believe how long it lasted after the grease was washed out of there by salty water and mud. I always thought a ripped boot was the kiss of death, maybe for a front wheel drive 4 cyl, but mine held up fine. Earned a few grand plowing and got my moneys worth out of it. And actually, it never did get loud or fail. The opposite side went bad and started clacking, so I changed them both at once.
Mine died due to 2 factors. Out of balance (though they were fairly new) injectors, and a harmonic balancer that we bad, but made no sound, and looked great. Therefore I say, check your injectors at a reputable injector shop and, change that balancer whether or you need to or not.
I had also overheated the piss out of it the summer before.
but if you intend to keep it... would the synthetic not be a better investment than new engine?![]()
I thought about this thread quite a bit and I keep remembering a post by Schiker. He theorized that IIRC when things heat up that the fuel would be more apt to ignite sooner so in a way advancing the timing. Just wondering myself if the earlier ign could cause extra stress and be a contributing factor to cracks and such. I would imagine if it ignited soon enough that it would have a similar effect as preign on a gasser. I wonder if there is anyway to determine if this actually is happening? Would explain alot of failures.
I think the biggest benefit to modern common rail diesels is the better cylinder pressure management with injection more variable not directly dependant on crank timing.
