I changed it because I was in there already. I'm confused though.Even though I cut and spliced wires when I did my Lift pump relay upgrades, I prefer Leroy's plug and ply harness. If I do another, I will either use Leroy's harness or make mine similar, by running wires down to plug into the lift pump plugs. I also do the prime feature by Tapping into the glow plugs to trigger the relay while the glow plugs are on.
Maybe we should go back to the old lift pump relay threads and mention the new and improved plug and play method. I never did like splicing into factory wiring if it could be avoided.
When doing the relay upgrade is it rarely necessary to change the OPS. Even though it is not putting out enough juice to run the lift pump, it is more than likely putting out enough juice to trigger a relay to run the lift pump.
Also isn't the check engine light supposed to come on in the wait to start position or auxiliary position like a gasser or no?
