What does the transfer case in the 1996 Suburban take for fluid?
jrsavoie
Recruit
Rural Clifton, Illinois
I have Some Royal Purple here that is supposed to be a replacement for Auto Trak.
Or does it take transmission fluid?
Most transfer cases use ATF.
IIRC aluminum cases use ATF and cast iron cases use gear oil, as a rule of thumb.
If it doesn't have auto 4WD option on the dash switch, then it is a DEXRON 3 type fluid. The autotrac/smurf oil is OK but not really reccomended for the dexron 3 applications.
