whatnot
No, just the regular before. They claim you get 15% less tread life with it.
I just ordered my second set of them today. (got 285/70/17 with Kedge grip this time)
When I ordered last time they didn't have E rated so I have D's on my truck right now.
They lasted about the same as anything else. (which isn't long for me )
The ones I would get do come in an E rated. I don't think I would put anything less on a 1 ton truck.
How are you guys seeing the front tires holding up being that those are the wheels that are making turns and get the most abuse (other than your rear tires it sounds like Robert)? :hihi:
Don't get too hung up on "D" vs "E". Depending on size of tire some "D" will have a higher weight capacity than an "E" of a different size.
Check your door sticker and see what load range the manufacturer recommends. Not all one tons call for a load range E (though, like you, I prefer them for that little bit extra security)
On my dually with BF Goodrich Commercial T/A Traction tires (load E though GMC only calls for D) I'm getting quite a bit of cupping on the fronts, despite proper balance, inflation, alignment and good Bilstein shocks all around. The alignment shop told me it would probably happen, claiming the tread is too aggressive for the fronts, but I'm finding that regular rotation helps to keep it in check, though I'll probably get reduced treadlife. Since they came with a 60k tread warranty I'm not too worried. I'll probably get 40k out of them and take the pro-rated discount on a new set when they wear out.
If it's not 4x4 why tractions on the front?
you need a good highway ribbed tire...my 96 Dodge Cummins dually 2x4 w/front end in perfect mechanical order, used to eat anything (a/t or a/s) you put on it ...I was changing front tires at every 25k on the front...then I put a set of Michellin XPS Rib on the front and put 65k on them and they still had tread left(at least 15k) on them when I traded it for the Dmax...sometimes you get what you pay for
