What are the preferred injectors?...
Mezmorized
Ottawa, Ontario, Canada
I did a few searches and couldn't find what people prefer for injectors on the 6.5's... That and the Glow Plugs of choice as well, from what I've been reading they probably are the ac delco 60G's?
duraterms for me tough call on injs as you can't tell what kind of nozzle they have in them without pulling them apart
60g and duratherms are the only good GP options.
Bosch German made injectors are the best, followed by India made, the problem is there are knock offs for both, and as Ak said if someone rebuilt them they could put any nozzle in any body. Finding a good rebuilder is the key. Even if you buy a new set take your old set to a good rebuilder and have them gone through. If your new set is a cheap set you'll only get about 30,000 miles before swapping them. If you can afford the down time just pull yours and have them rebuilt.
Duraterms heat faster than the 60G's but both are slower than the factory plugs. Look into ways to extend glow time aka in the tune for a 1995. I have used both and prefer the duraterms esp with worn or damaged injection systems.
I run 60G's whenever i am in one. bosch german bodies, but I havent found a source for bosch german tips (anyone know of one? ) so I have to run bosch india tips.
If you live in Ontario, get the Bosch Duraterm.
For injector, the stock Bosch injector is recommended as supposed to the so called Fake Marine injectors or Chinese Made injectors.
