preachermic
I need to do some welding on my chassis. Is there any precautions I need to be aware of concerning electrical?
Disconnect the battery grounds and you should be fine. Leo
- Keep your ground clamp as close to the work area as possible, what are you welding?
Are you guys saying welding in an upward directions is alot weaker than a welding in a downward direction? (using gravity to help the tool?)
Intersting, and intriguing, can someone explain why this is?
If we where welding on pipes we did weld down, but we always used a I beleive it was a 7022?
He also used to pose the following question on a regular basis: Why do welders make such good lovers?
Sparky,
