FellowTraveler
WHY WATERLESS COOLANT, WHY NOT?
I have no interest in nor am I affiliated with and commercial entity mentioned herein and only use their products without compensation.
I see very few using waterless coolant and most others are sticking to old school theory’s “ethaline glycol & water” (EGW) is less a hassle to justify not switching, or OAT’s coolant is what GM™ recommends.
I did the switch to waterless coolant years ago and I’m confident it was the right thing to do.
Take EVANS™ “which is what I use” waterless coolant as an example; it virtually eliminates corrosion, steaming, cavitation and electrolysis it has lifetime service and can be run at zero cap pressure to eliminate cooling system pressure load.
If perhaps something happens to compromise the cooling system and in worst case water has to be added to get going the waterless coolant will not work as well as designed so drive accordingly however this added water can be boiled off the waterless coolant so it’s not all wasted. Water boils at 212 +- deg. f waterless coolant somewhere near 400 deg. f without pressure cap.
Using a zero pressure cap the only pressure the system sees is pump head pressure slightly compounded by inline coolant restrictors (heater hose & bypass) which quickly falls as coolant exits motor so hoses, radiator and heater cores never get exposed to pressure that expands and that can even blow a hole in an older hose and in some cases blow the hose clear off or burst a radiator tank. A pressure cap can be used with waterless coolant to raise its boiling point however un-necessary in most applications as it has a boiling temp of just less than 400 deg. F without pressure cap and without engine damaging steaming can your EGW claim that?
FACT; waterless coolant and zero pressure cap the radiator, hoses and heater cores never see high pressures then factor in no more corrosion, steaming, cavitation or electrolysis all leading to much longer service life of all cooling components and the engine itself.
EGW always requires a pressure cap to prevent water from boiling at various temps however “steaming” is a common problem which is not controlled by the EGW this is why GM™ designed steam lines in the 6.5td motors and on the later LS series motors that uses an accumulator tank. EGW related steam develops around valves and cylinders exponentially so temps rise at those components even though your engine coolant temp gauge may show normal temps. The EGW has proven track record that it cannot remove this heat around the valves and cylinders resulting in cracks and other heat related issues commonly seen in the 6.5td. There is a legitimate argument about the substandard metals used in various 6.5 castings and IMHO EGW and the resulting steaming just exacerbated the problem.
Yes, IMHO distilled water with water wetting products is just as bad simply because there is still water in the mix and it steams always around the valves and cylinders no matter what your temp gauge may show as normal temps.
Add to the EGW mix any turbocharger and things get worse when exhaust gas temps (EGT) are not kept under control resulting in even more damaging steam around valves and cylinders when using EGW mixtures. Major advances in more efficient turbochargers available for the 6.5td reduce the heat load too. When waterless coolant replaces the EGW in this turbocharged environment steaming and the resulting damage simply cannot happen in good engine/head castings however there is not enough data on older castings using waterless coolant. Top engine rebuilders are adamant about using only GM™ enhanced blocks (May 1999+) the NAVISTAR™ cast optimizer and newer P400™ for any rebuild I’ll add waterless coolant will ensure proper cooling under all conditions.
Another argument is about GM™ max temp recommendation for the 6.5td being lower than the military 250 deg. f limit perhaps the HMMWV cooling stack being more efficient is why. So IMHO anything to enhance the GMT400 w/6.5td cooling is a plus and will allow safer higher and more efficient operating temps using waterless coolants without worry of steam heat related engine damage.
In the time since waterless coolant was introduced the trucking and aviation industry using waterless coolant has proven this higher operating temp efficiency as a matter of fact.
I’ve have successfully converted an GM™ enhanced 6.5td a NAVISTAR™ cast 6.5td a 500+ HP AMG™ Mercedes™ and will not ever go back to EGW.
