Water in tank
Kunjanlama
Hello I have a water in tank problem and I think it is making my truck to drive rough. I have 1988 6.2l chevy p30 step van. I tried to drain the water but I could find how to drain the fuel or water. I saw one where you drain water from fuel tank but my truck starts and fuel dont come. Can anyone please tell me how to drain fuel or water from truck and where the valve is located. I couldn't find the valve or fuel tank draining place.
Jaryd
Extremely Deplorable
Hodges, SC
I think your best option is to drop the tank and drain it that way. That way you know that you got all the water out of the tank and then run the fuel lines in a jug of diesel and run the van for a little bit so you run the water out of the injection pump and injectors
ak diesel driver
6.5 driver
alaska
If I'm feeling really lazy I jack the truck up in such a way to get a corner of the tank low and then drill a small hole and have at the ready a metal roofing screw ready (they have a gasket) then zap the screw in when the water is gone. Nice thing is you have a built in water drain. Start with the smaller roofing screws and then if you need to you can use a bigger one.
Jones
the drain valve is usually somewhere near where the front of the leaf spring is attached.
It's actually a siphon valve so you have to hook a hose onto it and then use suction to get fuel through and then drop below the level of the tank to get a siphon going. I had to blow some air into mine first to clear the crud from the line. (remove fuel cap first)
