Walbro Lift Pump Fail
Has anybody ever found source part # of the in tank "sock" gasser socks do fit but do not have the bypass check valve in the end in case cold weather "gells fuel" over gasser style screen. I kept mine as it is 70 micron protection that the 6 micron on engine would have to manage unless you also have a frame rail large capacity Racor 30 micron that I also added.
There would not be a lining unless someone coated it in the past however; there is a baffle that is held in place by push on clips washer combo they are known to pop off then drifting around the tank could occasionally get pulled to the pickup by the pulling of the lift pump and the baffle moves around too.
I’ve replaced the tanks and lines on my ‘99 and ‘94. At this age, they are done.
