daiglesteve1965
- Messages
- 15
- Reaction score
- 39
I was wondering if I could upgrade my 93 6.5 engine.to a newer engine that has less trouble and will bolt up to trans.thanks
Although 454 is a good option - if you go gas, then I would deal with the electronics and get a 6.0 LS. More power, better mpg, longer life than the 454.
Right- there is dozens of options. But @daiglesteve1965 needs to share more details to his situation and desired outcome.I never said it was the best option. Though there are plenty of factory EFI 454s and 496s out there too. The Vortec 8100 puts down better numbers than the 6.0 out of the box, though it's going to be guzzling considerably more gas doing it.
Would the Dmax even fit in the engine bay though? Thought I had read somewhere that they're too tall to fit the GMT400 trucks due to the lower hood compared to the factory Dmax trucks. I never really looked into it though, as I never planned on going bigger with this truck.. just planned on going straight into a medium or heavy duty chassis.
What turbo would you recommend.dont want to spend a ton.Options for a worth owning 6.5:
If you can do that (acceptable by local dmv and emissions folks)
Rip off the ds4 and get a db2 = loose all the electronic engine nonsense
Get balanced flow waterpump with better fan clutch and fan for cooling
Proper turbo instead of the gm mity-mite with 4” exhaust all the way back.
There is other stuff to make it a more secure rig too. Powermaster 9052 starter to spin it like it should. And AC Delco 60G plugs to make it start like it should.
Is it the GM4 or GM8 turbo that the Honda rice rodders want?The turbo choice has to fit what you are doing with it. The factory one is simply too small. In a suburban it definitely is too small trying to move that weight.
Hx35/40 hybrid is a great move. Hx40 is good if you don’t need all the torque from the stop sign. @Big T could tell you his call on the ATT in a suburban. But the ATT is better on ds4 than db2 because no waste gate means harder to spool up, but sure breathes easier down the hiway- especially when loaded.
When it comes to more fuel- that depends what you are doing.
I know several people that went to a hx35 and 4” exhaust, nothing else- quite happy with the change. The gm turbo which is prized by many 2.2 honda owners for being a great fit for them- is simply too restrictive.
The banks sidewinder was a tiny bit bigger than any of the gm options that gm came out with after the fact. And it was all about faster 0-40 mph pulling a trailer and having nothing else changed. Banks saved the platform, and was focused on an affordable upgrade for the natural aspirated anchor.
Big boy ip, turbo, injectors, etc- yeah really good power can come. But most don’t go into 6.5 for that. They just buy a cummins or dmax.
Yup. Well, it used to be. The availability of turbos now has greatly improved so idk if they still want them or not. But 10 years back- they were scouring junkyards and would here the 6.5 and come up to leave their number with ya incase you decided to get a proper turbo. The 2.2 shifting at 6,000 rpm had the turbo screamin is like a 6.5 at 2,000 rpm.Is it the GM4 or GM8 turbo that the Honda rice rodders want?
A bigger turbo isn't going to do jack all for you without the ability to flow more fuel as well, the factory injection pumps on these things are close to maxed out already, and the factory turbo flows more air than the pump can handle already.
Sure, throw a bigger turbo on it, along with a worked over pump. Oh, don't forget bigger injectors too. Now you've got a 250HP motor that has cost you a few grand, and running on the edge of ventilating the block.
Look around...there's a reason why there aren't a ton of highly modified 6.2/6.5 motors out there, and those that are required the owners to open their wallets wide. The people that recommend this stuff are the same ones that think EFI is garbage and a carb makes a motor more powerful and more reliable....because they can fix it with a screwdriver..while ignoring the millions of EFI cars that routinely go 200K+ miles without ever taking a tool to the motor.
Thanks ! New to diesels.jist looking to do the things I need to for better mpg.having block and heads done next week.so just looking to improve what I can.will be daily driver..I'm looking for dependable and best mpg I can get.tjanks againA bigger turbo isn't going to do jack all for you without the ability to flow more fuel as well, the factory injection pumps on these things are close to maxed out already, and the factory turbo flows more air than the pump can handle already.
