WildWilly
More problems, I was driving yesterday and my truck lost ALL power and is smoking heavily. This is a whitish smoke and smells like raw fuel. I just filled up my tank and added one small bottle of lucas additive. My guess is an injector or two are sticking open or maybe a push rod has slipped off but the truck is not really missing, it just smokes bad and will only run about 10 MPH or maybe slower! It seems like I have done nothing but worked on this motor since I installed it. I am getting some air in the fuel lines and have tracked it down to where I need to pull the tank to fix but it was running fine until it started smoking and lost ALL power.
- Year: ___1993___
- Truck model and class (ie: c2500) ___GMC K3500______
- Automatic or Standard ____automatic______
- Mileage: (indicate miles or km) ___213,000 miles______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ____95 NA IP 1/2 turn_______
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? _____Turbo_________
- Ambient outside temp: (indicate *C or *F) _____70 F_____
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ____#1_____
- What fuel additives are you using? ____Lucas oil_______
- Where are you located? _____Northern Kentucky________
- Air filter ___new______
- Fuel filter ____new_____
- CDR Valve? ____3 months old_____
- Coolant – last flushed/replaced at _____3 months ago________
- Oil – synthetic/regular, changed at _____regular just changed______
- Batteries – state of charge, (matched set) replaced at ____good_________
- Battery cables and grounds (removed, cleaned and tightened): _____yes_________
- Glow Plugs - how many miles on them? ____new_____ What type? _______AC delco______
- Injectors - last changed at ______?_________
- What were you doing when it happened? ____pulling a hill with a small car trailer on the rear bumper__________
- How was the truck running fine before this problem appeared? _____running great________
- Has this problem ever happened before? ________no_______________
- Describe any related factors that might be part of the problem. ______getting some air in the fuel lines from the tank area________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _N___ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? ___YES______
1b] Does the engine crank over? ___YES_____
1c] Are your batteries fully charged? __YES_______
1d] Have you removed, cleaned, and tightened all battery connections? ___YES_____
1e] Does your Wait to Start light come on for a time? How long? ___Bypass______
1f] Does your glow plug light come on? __yes_______ For how long? ___10 seconds______
1g] Do you see smoke from the exhaust while cranking? What color? __no______
1h] Does the Service Engine Light Glow during Start/bulb check? __yes______
2a] Can you hear your lift pump working? _____yes_______
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ____yes_____
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___yes________
2d] Loosen an injector line and crank the engine - does fuel come out? ___yes______
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ____yes_______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ___MANUAL IP________
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: ___________
3e] PMD Age: _____________
4] Stalling Issues
4a] Do you experience stalling only when hot? ___NO_________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4d] Is stalling momentary (engine recovers)? _________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ___NO____
5b] Any bubbles or oil film in coolant overflow tank? __NO_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ___NO_______
5d] Excessive white smoke from exhaust on cold start? ___NO______
5e] Excessive black smoke from exhaust under hard acceleration? ____NO______
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ____NO_______
6c] Have you added a performance PCM (reflash) or Chip? ______NO________
6d] Have you changed exhaust / downpipe / crossover? ______NO__________
6e] Wastegate – mechanical or vacuum (OEM)? ____mechanical OEM__________
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? ____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
- Year: ___1993___
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
