Correct - the 6.5 is an air pump, capable of ~400cfm @ ~3000rpm - the turbocharger is an air pump - if it pumps 400cfm into the 6.5 pump, intake to exhaust airflow is 400cfm @ 0psig (15psia Baro), no matter what size turbo is puffing into the 6.5 - the turbo from the Titanic would pump no more air at 400cfm than the GM-8 - however, as airflow (volume) output of 1st air pump begins to exceed flowrate of 2nd air pump, that excess stacks up in the intake as pressure - the greater the pressure, the greater the available volume\airflow - add fuel to suit
There are only three ways to increase airflow volume thru the 6.5L pump - (figures are general to illustrate concept):
- increase displaced volume: bore x stroke -
6.5L = 400cfm @ 3000rpm .....13L = 800cfm @ 3000rpm
- increase rpm: 3000rpm = 400cfm .... 6000rpm = 800 cfm
- increase inlet pressure with a 'charger:
3000rpm @ 15psia (Baro) = 400cfm
3000rpm @ 2xBaro (15psig Boost) = roughly 1.5 x 400cfm
Exhaust Back-Pressure is resulted from any restriction in the exhaust path, including the gas-turbine compressor motor - exhaust pressure of 2 to 3 times Boost pressure is acceptable, considering that cylinder pressures were just up around 3000psi as power stroke begins - the larger the turbine, the less restrictive the path, the less EBP, within limits: takes a lot of power to compress air - takes a lot of exhaust energy to make that power - increase turbine size above available exhaust energy level and Boost output will drop accordingly - trick is to size the turbine motor such that it will power desired Boost levels while providing least restriction - the higher the exhaust pressure at the end of the exhaust stroke, the greater the remaining junk in the cylinder from the preceding combustion event, which is the equivalent of Exhaust Gas Recirculation into the fresh intake air charge, reducing the amount of fresh O2 needed for combustion - reduce exhaust back pressure to get fresher air in the cylinder for more efficient combustion cycle
Thus, the engine with properly-sized turbo will make greater power at lower Boost pressures - the correctly-sized compressor will pump cooler air into the intake, cool air being more dense than hot air = better power from greater efficiency at lower pressures - lower compressed cylinder pressures = reduced pumping overhead from less rotational resistance during compression stroke
Far as charge-air coolers vs water mist injection, pros'n'cons are listed on vendor websites - I prefer the simpler c-a cooler, simple to install, simple to maintain, no fuss no muss - add a Provent to really clean up yer act - if I regularly towed\hauled thru Death Valley or thru the American deserts, I would prolly install wmi, butcept have it spraying over the c-a cooler, which would also help cool the engine coolant radiator, because of burning the A\C to help the driver survive the heat - would require a large water reservoir and accessible replenishing supply source
Most of the loss of pressure across a properly sized and mated to your system c-a cooler is due to the reduction in flowing temperature across the 'cooler - compressing air makes heat, heat creates expansion, a gallon of hot expanded air has less volume\mass than a gallon of cool air - which is why engineers measure airflow in mass\weight, rather than volume - street is still stuck on cfm because that's the way carburetors were sized - everyone wanted the dual-pumper 750cfm or 850cfm, or the huge 1050cfm Holley's over the girly-man 550-600cfm versions that rolled off the assembly line
