Turbine Doc
Just Another Diesel Guy
I got rid of my IC and have not regretted doing it
Water injection would be better than intercooling
already have intercooler
I dont think with a fixed volume (intake size) that you can have more CFM with less PSI since they are related. However the advantage on ATT is the no wastegate, lower backpressure makes the diesel more efficient at lower boost. As well as a more efficient blade pitch or turbine system in general, than our Borg-Warner OEM turbos.
But the exhaust port is closed when the intake port is open right and vice versa? So the cyclinder would be the choking that doesnt change, which is why we go for higher displacement
I'm sure that youre right though, there has to be some greater flow into the cylinder allowed with the lower backpressure
