Acesneights1
Well the truck pull in Ellington is approaching and the M1008 needa the Turbo. Somehow I don't think 155HP is going to cut it. My dliemna is how o do it.
Here is what I have RIGHT NOW;
Both Manifolds of a 6.5TD
GM4 w/TM(Thanks for great deal VW Lupo)
Plate for the return line(Thanks , but I forgot who gave it to me and feel really stupid)
F intake.
Cone filter(Thanks PAveltoz)
Peninsular Upper intake(Thanks ChrisK)
I have no ex components.
A 6.5 Crossover will "probably"work due to my lift kit but I could also have one fabbed since a buying a kit may not be worth is as the DP will be useless. I have the DP off the Dually to cut for the turbo flange so ex shop will do the rest. Now the dlimena..
I at minimum will have to swap my injectors(only 59k on them) to shortys and eat the core charge to clear the 6.5TD manifold so that is 320$ right there.
The guy who sold me the Dually has most of a Banks setup for 500$. Eitherway I need ex. The Banks manifold would allow me to not have to buy short injs and I know it will fit fine.
What I am thinking is....
Buy the banks,
Use the GM4 and the F intake(The banks intake setup IMHO sucks. It has been reported that Banks users who switched to a 6.5 F intake reported substaionally less turbo lag).
And then fabb all the ex from local shop. I have never seen a BAnks setup up close installed, so I don't know how they run the ex out the back but on 6.2 with 6.5 setup, the only way to run the ex is outside the frame unless a body lift which this truck will never see.
Wayyy too much work to install a bodylift on a CUCV.
The only other hing I am uncertain about is whether or not the Banks will clear the aux alt but from what I have read on SS it should. The guy is cool and would probably let me try it.
F intake.
Buy the banks,
