Transmount problem. Help?
dmaxpwr12
Elburn, IL
Im not positive it is a transmount problem but when i come to a complete stop then let off the throttle i can feel a huge jerk underneath the center of the cab. Transmount??? Motor Mount???? Please help!!!!!
Try going underneath and apply some torque on it with a prybar just don't get the pan. It is usually easily to tell when they're bad that way.
Welcome to The Truck Stop! :welcome2: Tell us about your truck. That happens a lot on LLYs and occasionally does it on LBZs as well as LB7s. It's a hard downshift to first. When was the last spin on filter change and trans fluid change? That can aggrevate the problem.
Sent from my SCH-I535
Well hello their Big Mike!!!! I installed a new spin on filter about 3 months ago. And changed the fluid about 1 year ago. The shifting occurs when the trucks already in 1st gear. Say I come to a complete stop at a red light, keep it in drive gear, the light turns green, right when I let go of the throttle to accelerate is when it shifts.
Mine did that slamming into 1st occasionally. Slow to stop then *BANG* it hits 1st and feels like you got rear-ended.
Almost sounds like you've got the old dry slip yoke though since it's already in 1st.
Hi Ben. Where the driveshaft yoke goes into the back of the transfer case the spline is dry and with the miles you have on it I'd think you would benefit from pulling the driveshaft and grease the spline real good before reinstalling. Do some prybar checking like Will suggested while you're under there.
Awesome thank you!!! I actually did grease that about 2 years ago. Its stopped the problem for a while. Im glD u mentioned it now I remember
Good deal. Let us know how it works out. Feel free to look around and discuss anything at all that's on your mind. Alot of damn good guys here.
