I have a 1993 Gmc siearra k3500 with a 6.5l turbo diesel. Now mind you I know nothing about diesel engines. but here is my question the last time I drove the truck the transmission while driving acted like I shifted it into nutral. when I check the trans fluid it looked good but when i went to wipe it off with my fingers it burnt my fingers because the stick and fluid were so hot. now the temp gauge does not work in truck. so the question that I have is will the truck overheating cause the transmission to slip out of gear. I also want to mention is that it only does it when the engine is warm. If i start it up and drive it before the truck is warmed up it will shift just fine but as soon as it warms up then it slips out of gear.
